Cambelt Cog
SuperRedMR2
Cambelt Cog
Post by SuperRedMR2 »
Hi,
I've removed my cambelt tensioner and now I need to remove the cambelt cog wheel.
It's not coming off very well.
I cannot get a puller behind it.
Any ideas?
LimeyMk1
Re: Cambelt Cog
Post by LimeyMk1 »
That's a fun one. IIRC I got a pair of screwdrivers behind it and gently levered it out until I could get a puller onto it.
SuperRedMR2
Re: Cambelt Cog
I'm going down the screwdriver/chisel route with not much going on. Can't get a hammer on either as there is just no room to manoeuvre it!
LimeyMk1
Re: Cambelt Cog
Post by LimeyMk1 »
SuperRedMR2 wrote:I'm going down the screwdriver/chisel route with not much going on. Can't get a hammer on either as there is just no room to manoeuvre it!
If you can get some plusgas/penetrating oil into the woodruff ket slot that sometimes helps it slide off.
Yup there's not a lot of space to faff about down there. From what I remember (been a few years) if you don't get the pressure even in both sides it can jam, so a little tap back in with a big deep socket (30mm one) helps straighten it out and also loosen it up.
Polypedates
Re: Cambelt Cog
Post by Polypedates »
By cambelt cog wheel do you mean the cam gears or the pulley on the main crank? The pulley has two threaded holes on the spokes to take a puller and the cam gears can usually be prised off with a proper pry bar then a puller as already suggested.
