[Mk2] [Turbo] low power/ low torque
Re: [Mk2] [Turbo] low power/ low torque
you say original is there copies going around and how can I tell if im getting an original????
goggins1234 wrote:you say original is there copies going around and how can I tell if im getting an original????
You could start a new thead on
Check to forum for sales
the OEM bov if working correctly doesn't leak either and it's design means it holds better as the boost goes up.
Sure if it's broken then it's crap, as are most broken parts
If you're not getting fuel cut while driving then clear the ECU codes, there's a guide here somewhere for that or search google but basically with the ignition off, remove ECU a and ECU B fuses, also the EFI fuse.
Two of those fuses are in the engine bay box and the third one is in the front fuse box near the suspension turrent.
Keep the fuses out for a minute of so, put them back in and go for a drive.
If you then get any error codes back, you know the car has an ongoing fault.
Good work finding the leaks so far, that helps greatly
I youtube'd the real and fake hks ssqv
I did reset the ecu and the codes haven't come back and I've been booting it tried my best to see if I could get fuel cut but nothing
I completely removed the mbc
im gonna check the stock bov in the morning fingers crossed
think its something I'd like to replace though tbh
When you think how many miles/km its done since new personally I think its well worth it.
Hope you find your fault and its a cheap fix
Ps.
no point in replacing parts that are working fine, spent the money on the EBC instead.
Removing the battery strap works fine, also wipes the radio info and sets off the car alarm on reconnection too.
Removing the fuses and then checking oil and coolant levels before putting fuses back in, simple quiet and useful time spent
I just want it running right tbh
love my 2 its the 1st ive owned and so addictive
I do my mrs head in lol
I will check the stock bov 1st thing and take it from there
got the cash to buy parts and no one wants to sell to me lol
If its not the bov, Like I said it process of elimination
, we will get there in the end
cheers mate thanks for yours and everyones help
superb
superb
afternoon to all
checked my stock bov this morning and its fine
no leaking when I blow into the hole which was attached to the hot pipe
gts chris as agreed to take the mbc back and refund me
managed to get me a Greddy Profec B Spec II Boost Controller
any tips on installing and setting up would be great
should be here in a few days Saturday would be nice
OH mate that's brilliant thanks a billion
