Where can I pick up a new pair for reasonable money?
Tsporter wrote:Thanks for the reply.
I could get them cheaper from twosrus myself.![]()
Pm me if you can do any better with the price.
And I'm living in Ireland.
Ollie@PacificWorks wrote:Surely these can be manufactured over here at a much cheaper cost?
bwrc wrote:This report is worth a look regarding after market rear tie bars
http://www.matrixgarage.com/content/aw1 ... e-rod-test
LimeyMk1 wrote:Ollie@PacificWorks wrote:Surely these can be manufactured over here at a much cheaper cost?
Potentially, the two ends are'off the shelf' items
(Mk1 front steering end and the rose joint).
However the centre bar may be custom fabricated and possibly the spacers too.
You'd have to sit down and crunch the numbers, but I suspect it'd be a close run thing for a set of the same quality.
dazzz wrote:I'm no expert but
totally agreekaiowas wrote:You arent going to bend either type of tie rod in normal use.If you're running huge cornering loads due to slicks, aero and trick suspension or have habit of bouncing of kerbs at speed then you might have an issue but for typical road use it's a non-issue.
