Hi everyone,
I think my car needs mapping the idle is high and I think it is over fueling on wot causing a misfire. All I can smell going along is fuel (no leak). The car is a beams turbo. Thanks.
Sam
Good mapping place link ecu
Re: Good mapping place link ecu
Thor racing .. http://www.thor-racing.co.uk/Link-308.asp not cheap
http://www.tuningdevelopments.co.uk/index.php?cPath=624
Hopefully not too far away, about 40-50 mins depending on traffic.
Thanks guys. I think it was done by 2bar last time Ryan isn't it? On Thors dyno. I don't think he touches Link anymore =(. Really need to ring Patrick when I get chance to try and sor out
Draven wrote:http://www.2bartuning.com/
samgpr50 wrote:Thanks guys. I think it was done by 2bar last time Ryan isn't it? On Thors dyno. I don't think he touches Link anymore =(. Really need to ring Patrick when I get chance to try and sor out
Shame about thor thought they still mappped link ecu's and quite close to you (ish), if you can make it to ryan at 2bar, he really does seem to have the magic touch when it comes to mapping
2mad wrote:samgpr50 wrote:Thanks guys. I think it was done by 2bar last time Ryan isn't it? On Thors dyno. I don't think he touches Link anymore =(. Really need to ring Patrick when I get chance to try and sor out
I emailed them the other day about a Link G4 for mine. They can supply, fit and map one for me so they still do Link
simba90 wrote:2mad wrote:samgpr50 wrote:Thanks guys. I think it was done by 2bar last time Ryan isn't it? On Thors dyno. I don't think he touches Link anymore =(. Really need to ring Patrick when I get chance to try and sor out
That is good news looking forward to seeing what numbers you get
If you get a chance bring this thead back from the dead and post them up.
I would keep clear of Thor, they fitted a link to a friends car and he never made it home before the engine blow up, replaced engine, went back to them and the second engine did the same.
I have heard of similar things from Thor also... Which is a shame
Ryan at 2bar it is then
Some good results from 2bar so I'm kind of wondering if they mapped your car first time round why you needed to ask the question? It's obviously not a distance issue , why not just pick up the phone and ask if they still map link ecu's next time?
Maybe it's just me but I can tell you who where and when my car was mapped and I keep my plots. Personally I wouldn't travel as far but if he's that good then for you it's worth the extra miles.
http://www.indigo-gt.com/
had mine done recently at indigo gt in tredegar. I tried getting ryan to map the link ecu I have fitted (which I also bought from him) but he just said he doesnt work on those ecus anymore.
contact number for indigo gt is 01495 719720
