My drivers door window goes down about half way and stops with a clonk then wont come back up unless you lift the the window glass.
I know the plastic gogs are a weak point but not sure this is the problem.
i am reluctant to pull the assembly out without some spares to hand and thought a passenger side assembly may be useful, as they do not get quite as much use.
