3sge pcv valve
adzmr2
3sge pcv valve
Post by adzmr2 »
hey guys
noticed that i dint connect the pcv valve on my rev234 engine, so i know on the rev 3 it connects to the vacuum on the inlet and the rocker cover. so i've drilled into my rocker and stuck in the valve, but with it connected the car wont run, disconnect it and it runs.
Any ideas? Could it be another vacuum causing the problem?
Ta
Adz
Peter Gidden
Re: 3sge pcv valve
Post by Peter Gidden »
What's a rev234 engine? :?
adzmr2
Re: 3sge pcv valve
Post by adzmr2 »
ha my engines built from a rev4 block, rev2 head and rev3 inlet manifold
:oops:
