[Mk2] [NA] Dash Removal???
Andy_MR2_Rev2
Post by Andy_MR2_Rev2 »
Hi all,
Does anyone have a guide for dashboard removal ?
thomp1983
Re: [Mk2] [NA] Dash Removal???
Post by thomp1983 »
No guide but ive pictures of the majority of the locating bolts for when I refit mine, it's quite a simple dash to remove
Andy_MR2_Rev2
thomp1983 wrote:No guide but ive pictures of the majority of the locating bolts for when I refit mine, it's quite a simple dash to remove
I will give it a go then, got a new flocked dash to go in!
thomp1983
Post by thomp1983 »
Ill post the pictures up tomorrow afternoon when I finish work
thomp1983
Post by thomp1983 »
pictures as promised,
that's drivers side there's one the same on passenger side
all the bolts you can see down left of stereo need to come out same for right side
there's also 1 bolt under the small vent on left hand side of dash the little one closest to screen it just pulls out and bolts in the recess. the top of the dash is held in with clips they just pull out with a sharp tug
think that's most of them but there quite obvious once all the trim bits are off
chris
