ashley wrote:Ask him to give you the following information:
Ring gaps
Piston to bore clearance(he should have specified this when he gave the block and pistons to the machine shop to rebore)
report back and we can see if that's your problem
GreddyMR2 wrote:My full gasket kit is Cometic including valve stems.Maybe they are poor quality?
But hopefully it will stop making smoke after brake in.
GreddyMR2 wrote:He checked and did bigger gaps, because it's forged pistons.I didnt ask the numbers.
He said I can even hear a bit of knocking when engine is cold, but I don't.
bobhatton wrote:
Your builder does not know what he is doing.
Ever the diplomat Bob!![]()
GreddyMR2 wrote:Unfortunately he doesnt remember the gaps.
What's more, the pistons and rings I bought are not new and the engine they were in was overheated.So builder says that I need to drive some more km to get them bedded in well, because the rings could be scratched a bit from overheating.
Also, this morning I saw less smoke than previously.But it was warmer outside.
