Putting the finishing touches to an rev3 turbo swap into a UK N/A rev3 body; This is the first time I've driven the car since the conversion and have had a few issues, the most important one is that there is no boost.
I've got an aftermarket boost gauge fitted and the needle only moves between negative and zero.
I didn't give the engine a hard time at all before this happened.
Any ideas where to start looking?
Could this be an electrical issue rather than a mechanical one? As I've retained the dash wiring loom from the NA and paired it to the Turbo loom from the passenger foot well back to the ECU.
Thank you
