I've run my mr2 na rev3 for almost two years now.
So far he has told me that the speedo acts up for the first few minutes of running on occasion, but returns to normal once you get going.
Going to view tomorrow so appreciate any advice
MR2 Rich wrote:I'd say NA's are more likely to crunch as they didn't sort the synchros out until Rev5.
Peter Gidden - SBITS wrote:MR2 Rich wrote:I'd say NA's are more likely to crunch as they didn't sort the synchros out until Rev5.
Huh?
MR2 Rich wrote:Peter Gidden - SBITS wrote:MR2 Rich wrote:I'd say NA's are more likely to crunch as they didn't sort the synchros out until Rev5.
Huh?
The Rev1-4 had weaker synchros on the NA's, the Turbos was only Rev1's.
Odin_S wrote:I'd say if the car is in good condition get it.However if you are going to be looking for more power 6 months down the line, hold out for a good condition rev 3+
Peter Gidden - SBITS wrote:MR2 Rich wrote:Peter Gidden - SBITS wrote:
Huh?
You are incorrect.
Huh?
You are incorrect.
ashley wrote:I think you've confused weaker synchro's with the availability of an OEM LSD on the turbos maybe? There was no OEM rev1 LSD for the turbos.
HTH
