mr2 won't start
n52
mr2 won't start
Post by n52 »
Hi all,
Cars been running fine until today. Went and got tyres drove all the way back and stopped for petrol. When I came back to the car I turned the key over heard like a knock noise from behind me and it wouldn't turn, no power at all anywehrre no dash lights or anything. Only thing I could think of that I changed recently was amp install. I took the radio out and it turned over so I turned it off put the radio back in and it wouldn't start, procceded to take the radio out again and nothing I've checked all the fuses so not sure what else to check?
Ryan S
Re: mr2 won't start
Post by Ryan S »
check the battery is connected properly first :thumleft:
Draven
Re: mr2 won't start
Post by Draven »
Make sure you have done the battery poles up correctly.
n52
Re: mr2 won't start
Post by n52 »
Battery is done up tight, all connections are fine. No fuses seem to be blown. The only thing I can think of is that my immoblizer malfunctioned. It started again on its own after about 10minutes and now appears to be running fine as usual....
bashracing
Re: mr2 won't start
Post by bashracing »
poor earthing? the loud click was the starter solenoid
