I was heading home at the time
On further inspection the water pipe had burst with no fluid at all left in the block.
But firstly what damage if any is likely to be caused by this to the engine?
Secondly what could have caused the pipe to burst in the first place? Water temperature was fine when i left because the car is always warmed up before driving.
Lastly when replacing coolant I'm pretty sure i have air trapped inside because my heaters weren't warm so thinking drain the lot
Any advice appreciated.
