Its a mk1b, been running well since i've had it for the past few weeks, starts first time straight away, engine has no issues and nothing to be worried about.
Today, i go out to it to go to the shops, and the car turns over but won't start up.putting foot on accelerator to give it some gas makes no difference.
Any ideas on what this could be causing this? My first thought is that it might be an immobiliser/alarm issue as my old mk1 had one and had these symptoms if i forgot to flick the switch to get the fuel pump running.
How can I check? Wasn't sure if it was related or not, but theres a wire coming from the engine bay fuse box which looks a bit ghetto'd and I can't remember what the part its connected to is called, but then another wire from same location loops through the engine bay and i believe back into the drivers side of the car.
Have attached a few pics which may help.
Any help much appreciated and any steps I can take to figure out whats wrong
G
