shinny wrote:megamonkeyman wrote:Are there any power gains to be had by swapping? I have a Rev 1 turbo converted to Rev 3 ECU, the only problem is there is no chargecooler in my setup.
Toxo's dyno graphs suggest there are minor gains to be had..
however the main reason we converted was for warning if the fluid level dropped or the pump failed.
The black line is the ST205 ECU, the pink the rev3 MR2 ECU..
Now my car turns on the CEL and reverts to safe mode whenever the coolant level is even a fraction low, it's got me to really sort out my system's headertank and bleeding situation, whcih can only be a good thing![]()
Good gains for the price but I do not want a CC setup due to maintenance on the engine and I agree,
Shame, the idea of better AFR's is almost too good to miss.
