Heya mate what you'd most likely need depends on the stud pattern of the wheels.
For example if you've got a wheel with 5 holes for the studs you'll likely be able to use normal 60 degree tapered head bolts
(not like the Flat Seated with washers that Toyota use as standard) as the hole will usually be bigger so you'll have more access to the outside of the nuts
(I'd usually go for 17mm heads)
If you've got multifit alloys then you'll likely need the slimline bolts with the internal thread if that makes sense?
Again you'll need 60 degree tapered head nuts
Either way in case you've not heard do NOT buy D1 spec nuts they're f**king awful and shear at a moments notice
Hope this helps
Ryan
