Fuel gauge/sender
David-Edmond
Fuel gauge/sender
Post by David-Edmond »
Finally recieved the log book for my mr2 last night so taxed it first thing this morning and its now on the road.
Put £20 fuel in it and noticed the fuel gauge still isnt working.
Have put signals up to the gauge and it works then, so not sure what the problem is. It had been sat for 2 years previously so could the sender need cleaning possibly?
jasongtr
Re: Fuel gauge/sender
Post by jasongtr »
the senders always fail
David-Edmond
fixed now the sender was just a tiny bit seized :)
bennn
Post by bennn »
Is it normal that the fuel guage takes a while to go up to full after filling the car? Its the only car i've had that doesnt do it straight away.
Harold
Post by Harold »
Mine does this, the needle slowly rises to the top, I just assumed it was normal.
madbasshunter
Post by madbasshunter »
Mine only goes to 3/4 when full and when it hits the bottom line it runs out the red light doesnt illuminate. Going to fit the sender out of my rev3.
Steve-O 2007
Post by Steve-O 2007 »
I have a working one for £13.50 posted from a Rev3 if anyone needs one :thumleft:
Lefty1991
Post by Lefty1991 »
my gauge works but the fuel warning light is constantly on, any ideas?
Baker
Post by Baker »
£20 is around 1.6 litres so thats probably why it didnt show anything! :oldtongue:
Baker
Post by Baker »
Lefty1991 wrote:my gauge works but the fuel warning light is constantly on, any ideas?
http://www.imoc.co.uk/forums/viewtopic. ... ning+light
David-Edmond
Baker wrote:£20 is around 1.6 litres so thats probably why it didnt show anything! :oldtongue:
What fuel are you using to cost so much. £20 Vpower is something like 13-14 litres for me :)
Peter Gidden
Post by Peter Gidden »
Low fuel switch has died. So you need a new sender unit.
Lefty1991
Post by Lefty1991 »
Turn out to be the low switch on the sender was just seized, a gentle tap sorted it. Worked fine now for over a year
Rob
Post by Rob »
How do you recalibrate the gauge to your fuel capacity?
MR2DIE4
Post by MR2DIE4 »
i had this on mine too, needle won't move, but the low fuel light works, so i pulled the sender out, apparently the sender was stuck. placed it back in correctly, all working fine.
next day i throw the car sideways at a roundabout, again stuck.
been doing this about 3 times, but can't be bothered anymore, it happenes all the time...
