Horn doesn't work
Gaz
Horn doesn't work
Post by Gaz »
Hi all!
Been rebuilding my rev2 turbo in the garage for a few months now, and its almost ready for MOT, except for the horn which doesn't work. I have no clue about car electrics which doesn't help! When I press the horn the relay doesn't click, that's all I know. How can I troubleshoot and fix this?
Jaffacake
Re: Horn doesn't work
Post by Jaffacake »
i recently had the same problem mine turned out to be a disconnected wire in the steering wheel, pop the centre cap off and have a look at yours. if all seems ok, test the horn with a fused bit of wire to the battery if it works then you know its a fault in your wiring somewer and not a faulty horn. hope this helps. :D
wilkie senior
Post by wilkie senior »
Hi
My lad (wilki) his horn packed in, once we looked the cable at the horn had corroded off the connection, worth a looksee
try checking there
it is under the slam panel at the front, if you have AC its tight but we managed using a mirror up through the front and a torch and skinned knuckles ha ha
Steve Horrocks
Post by Steve Horrocks »
Also check the bolt on it, have you painted around there, as the bolt holding it onto the car is its earth iirc
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
Beebaleen
Post by Beebaleen »
Hi Gaz, I have just bought my first MR2 and the horn wasn't working on there, I took the relay out cleaned the pins a bit (even if they don't look dirty) and then put it back in *Voila* try that.
Rob66
Post by Rob66 »
Mine was the same as Wilkies, wires had corroded so i needed to replace the wiring, having aircon in the way didnt help but all ok now.
Rob
