In the planning/research stage of getting my car back in top shape, I knew there was rust on it, and got new rear panels to weld in, and have been close to ordering front panels a few days now.
Decided to do a more thorough inspection on the car before ordering and discovered that the
The part where the lower arm mount meets the chassis is bent/buckled(not the bracket but the steel plates), I think it is off by as much as 10-15mm.
There is a 1.5 meter weld on the right side of the floor, about 10cm in from the sill, that have been covered with Tec7 silicone, the same goes for the left hand sill.
All this might help explain why i cant get the left side door window to seal properly.
Also, the paint on the car is ruined, probably done by the same incompetent turd that did the welding, so need to sand it down to metal IF i`m going to restore it.
I`m just so depressed after this, I do love the car so much, even if my brakes never work, the paint is crap and all the bolts is stuck when doing work on it.
And to make it worse, these cars dont grow on threes in Norway,8 years ago it was counted to 185 cars total, i expect about 100 still running, and maybe 50 which is not complete rust buckets(if the numbers is that high).
A few pictures: https://plus.google.com/photos/10557887 ... sOjG3fq6OQ
Thanks for reading,
Kim
