Peter Gidden - SBITS wrote:OP.
Has ignition timing been reset correctly?
Are cams dialled in correctly?
Yes, I have been assured ignition timing and cams are set up as per Hks datasheet, and Toyota manual.
dan4 wrote:Op also made it appear as if the engine was built to that spec before refitting?
ashley wrote:Nothing in there to suggest that he's changed his ISC spring![]()
Actually- you know what? I bet he made the mistake of replacing it with a denso spring instead of getting a genuine toyota one, that would explain everything..
.damn these cheap replacement parts!
GTMatt wrote:dan4 wrote:Op also made it appear as if the engine was built to that spec before refitting?
Engine was standard, and working fine.
Was then removed and rebuilt as per mentioned spec in original post.
dan4 wrote:The airflow characteristics have changed slightly, it could well be idle control.Or fuelling, anything changed on fuelling
GTMatt wrote:Mechanic ensured me the isc valve was removed cleaned and is functional.![]()
