[Mk2] [Turbo] lumpy at stead speed
Hi I have a rev 2 turbo which runs great until at about 60
-70mph when at a steady speed with hardly any throttle it jurks and runs lumpy till you give it more throttle then its fine.any ideas?
Re: [Mk2] [Turbo] lumpy at stead speed
daiodavies wrote:Hi I have a rev 2 turbo which runs great until at about 60-70mph when at a steady speed with hardly any throttle it jurks and runs lumpy till you give it more throttle then its fine.any ideas?
It will be in closed loop with hardly any throttle so under the control of the O2 sensor
I was going to change the o2 sensor but not sure what make to go for.
Any suggestions? Thanks for the reply
daiodavies wrote:I was going to change the o2 sensor but not sure what make to go for.Any suggestions? Thanks for the reply
Denso, on ebay.
I was hoping someone would say that as I sell denso.but Im not listening the turbo so do you know if n/a will fit?
