The RSRs are comparable to
the likes of Toyo R888's or Yokohama A048 with regards to dry grip, and significantly better than the likes of average street tyres like T1R or S02
(I've used both types on my VX220)
You would probably find a 205 rear has as much dry grip as a 225 road tyre.
Problem is thy aren't as good in wet or cold conditions, come with less tread new, and will most likely wear at a higher rate.
So maybe an option for track work, but unless you have some money to chuck at it and try various tyres types and configurations, you'd be better sticking to a proven set up with a more factory tyre stagger and similar tyre types front
/ rear IMO.
