The screen was the top end Pioneer AV unit when I got it a couple of years ago.
its dropped a few notches down the list now.
but was
£899 list when I got it.
got it from Hendon Car Audio for around
£670.
The Xbox was
£150.
plus
£20 for the chip, which i soldered myself, and a spare 40gb IBM disk I had.
That was the old setup, powered by a 300W invertor and a remote switching wire to the switch on the front of the xbox
(top left, and bottom right pins shorted)
The new setup uses the Espresso mini PC.
£150 with 64mb and 4gb disk.
I got a 256mb dimm
(£50) and a 40gb laptop drive
(£50).
Its running a VERY small isntall of Win XP, just for the better suspend/hibernate features that XP has.
The wireless remote was
£18.
from digitalcar.co.uk forums.
To be honest, its a much nicer setup than the Xbox
- it runs from a small laptop 12v supply, so no nasty invertor.
its tiny and small.
The other bits and pieces still use the Pioneer av head unit
(AVHP6400), but with an extra Pioneer MEHP9000 minidisc/slot cd head unit in the second DIN slot below.
a 12 disc CDXP1250 Pioneer changer, two Infinity Reference 7502 amplifiers feeding 655cs Reference components up front and 6502 Reference coaxials in the back.
The PC just connects to the aux-in of the av head unit to display and via a good gauge stereo jack to phono cable for sound.
Everything mixes through the av head unit, and through the amps to the speakers.
No speakers are driven directly and all volume is controlled by the rotary control on the front.
Sound sweet
btw.
Paul, you don't happen to work at Malvern, do you?
