Im aware of the injectors are maxed out at 16psi and got a modded fuel rail that has been honed out to 8mm with my mines ecu that is meant to lean out the fuel mix would some supra 550's or 540 gt4 level out the fuel mix and not run to rich if i was running 18psi
Cheers Karlz0r
