[Mk2] [Turbo] Smoking turbo cuts out
pete28
Post by pete28 »
Fine before parked up ,then got it out to play and a run to jappfest my 2 has started to smoke on idle (white smoke ) with white smoke I would presume head gasket but this doesn't show no signs of water in oil no mayo under the oil cap, this does only happen on idle when running its fine #-o , so after running to jappfest in the car she also starts to cut out at every set of lights or round abouts , so basically when car is slowing down, a little confused any ideas ?
Ethan21
Re: [Mk2] [Turbo] Smoking turbo cuts out
Post by Ethan21 »
Air leak maybe check vacume pipes
bobhatton
Post by bobhatton »
Turbo oil seals may have gone. Do you get any smoke on the over run?
Take the turbo inlet pipe off and see how much play there is on the comp wheel and shaft
Nic
Post by Nic »
pete28 wrote:so after running to jappfest in the car she also starts to cut out at every set of lights or round abouts , so basically when car is slowing down, a little confused any ideas ?
What year/revision is the car? Does it have a BOV fitted?
Nic
[email protected]
MR2 Rev 3 GT Turbo
pete28
Smokin rev2
Post by pete28 »
Yes nic it has a sard bob fitted could it be that ?
pete28
Smokin rev2
Post by pete28 »
Ethan thanks i will check pipes
pete28
Re: Smokin rev2
Post by pete28 »
[quote="pete28"]Yes nic it has a sard bob fitted could it be that ?
Ha bob ?????? Bov !!!!
pete28
Smokin rev2
Post by pete28 »
Bob thanks for the advice I will check the turbo ,
Much appreciated :thumleft:
Nic
Re: Smokin rev2
Post by Nic »
pete28 wrote:Yes nic it has a sard bob fitted could it be that ?
Have you just fitted the BOV? A vent to atmosphere BOV on a Rev2 - which uses a MAF sensor - could be the cause of the stalling issues.
Nic
[email protected]
MR2 Rev 3 GT Turbo
pete28
Smokin rev 2
Post by pete28 »
Hi nic the bov was on when I brought the car thanks for the advice I do have the old recirc of my old car I will fit it and try that
