Introducing the
Dark Fury project
400rwhp ATS 2.3L 5SFE GTX3076
I have been working on this project for some time and it's finally approaching completion.
![Image](http://farm9.staticflickr.com/8319/7946519566_fa64145f2c_b.jpg)
![Image](http://farm9.staticflickr.com/8309/7946785490_811744d95a_b.jpg)
It
dyno'd at 395.6rwhp on an ATS 2.3L 5SFE, Rev3 head, Greddy IC
(stock location) running a GTX 3076 Turbocharger
@ 1.8bar
My cooling appears to be the bottleneck.
Previously, I didnt want to go down the chargecooling or boot IC route but I'm re-considering.
See my full specs below.
![Image](http://farm9.staticflickr.com/8455/7952779916_15d72a9b7d_b.jpg)
![Image](http://farm9.staticflickr.com/8462/7952780360_621e0297ce_b.jpg)
Full credit goes to
Nathan at Century Motorsport![](./images/smilies/spacer.gif)
for doing a fine job working on this
- with great support from
Scott/Aaron at ATS Racing![](./images/smilies/spacer.gif)
and
Ryan at 2bartuning![](./images/smilies/spacer.gif)
I had some issues working with SBITS/Peter Giddens on my previous MR2
(rev1 TD06 tubby running 300rwhp;
having some issues is a f'in understatement!) and Nathan helped to get my MR2 goals right back on track
- installing a brand new ATS2.3L 5SFE bottom end on a rev3 head in a new 1999 chassis.
He communicated regularly
- providing updates every step of the way, went over and beyond his standard call of duty to answer my questions, check things out which I suspected may need further work and he proved his work rock solid, reliable and timely.
Ryan at 2bar tuning was central to getting the most power out of my current build
- spending a significant amount of time mapping my Apexi ECU given my cooling challenges and retarding the HKS cams as needed for maximum power output.
Scott/Aaron at ATS did a fine job building the engine and shipping it to the UK.
They provided excellent customer support and went out of their way to discuss my dyno charts whilst working closely with Nathan, Ryan and I to get the most out of the 5SFE and GTX3076.
James at 3S ![](./images/smilies/spacer.gif)
identified the issues with my previous MR2 and was instrumental in providing advice and guidance and helping me transition some of the mechanical parts to my new 1999 MR2.
Luke at Pacific Works![](./images/smilies/spacer.gif)
also helped a little, was a pleasure to work with and is worth mentioning.
All in all, Im happy with the result so far, the car is extremely reliable and has power on tap
very rapid and responsive whilst maintaining a comfortable ride for normal road use! I did however expect more power.
.I'm tempted to get better cooling as a first next step!
Thoughts?
![Image](http://farm9.staticflickr.com/8452/7946508740_000303eeca_b.jpg)
Specs![](./images/smilies/spacer.gif)
ATS 2.3L 5sfe shortblock
Wiseco 88mm Forged Pistons
Eagle rods
ITM Engine bearings
ATS Custom 1.2mm Headgasket
Revision 3 head
ARP Head studs
HKS 264 cams intake and exhaust
ATS Adjustable cam gears
ATS Throttlebody inlet
GTX3076 Turbocharger
Tial External waste gate
HKS SSQV BOV
GReddy Side mount IC
/ Berk Fan
ATS IC Block off plate
TRD Sports Thermostat
Spec stage 3 clutch
Lightened flywheel
4" intake with K&N filter
Blitz Nur Spec R exhaust
GT 4 bolt Downpipe
Sard 800cc injectors
ATS Bored Fuel Rail
Walbro 255lb fuel pump
Copper distributor cap
BC Racing coilovers
Blitz SBC-IDIII Boost controller
Apexi Power FC ECU
TRD High Pressure radiator cap
![Image](http://farm9.staticflickr.com/8313/7946504188_babc90dcf5_b.jpg)
![Image](http://farm9.staticflickr.com/8318/7946504814_b4836e0b56_b.jpg)
![Image](http://farm9.staticflickr.com/8039/7946506984_5a61fa5f88_b.jpg)
![Image](http://farm9.staticflickr.com/8034/7946507578_84884ea8b2_b.jpg)
RS
