Hi there.
My car idles cold at 1000rpm dropping to 300rpm when hotter and then dies.
Driving it is impossible, I put my foot down in first gear and it wont rev and pick speed up; it does however rev ok when not in gear
(or at least to 3000rpm, i've not gone further than that as I dont want to annoy neighbours).
The car has new spark plugs, dizzy cap, rotor arm, ignition coil and all new filters due to recent head rebuild with metal head gasket.
I have checked compression and I have 150psi on all cylinders.
there are no codes stored when I bridge Te1 and E1 and if I bridge B+ and FP terminals to keep the pump running the problem remains also.
I can stop the car stalling by revving it higher but soon as it idles it dies, if I rev it in gear
~(which it wont really do) the engine has no power.
With my timing light on any Ht lead the plugs seem to miss a spark every once in a while.
The igntion timing is on 10degrees when Te1 and E1 are bridged with engine hot.
or as close as damn it with such low revs.
Any ideas?
I have had the car for three months and only ever driven it 3/4 way home as HG failed
(thus rebuild).
I am at a witts end and just want to drive and enjoy the car but am just so frustrated with it.
Any help and ideas greatly recieved as im losing interest in it after having spent so much.
