[Mk2] [Turbo] car not starting and earth smoking! Help! *Now with MORE pics lol*
klx_boy
Post by klx_boy »
My 90 turbo is currently off the road due to needing a clutch, i took a few wires and bolts off as was going to give it a go myself however the car needs to be moved so i put wires back on where i thought they went.
I bought a new battery as the other was goosed, i turned the key and got nothing from the starter although a relay can be heard clicking?
Then there is a black earth wire under where the airbox should be connected to a mounting, that started to smoke so went to disconnect battery and both terminals where smoking and hot as hell!
I need to know where the earth point are/go and if anyone has a diagram of the starter so i can see if the wires are on right.
Thanks for any and all advice, Scott.
T.F.S.
Re: [Mk2] [Turbo] car not starting and earth smoking! Help! *Now with MORE pics lol*
Post by T.F.S. »
You have the battery around the right way?, if standing looking into the frunk the negative (-) is on the right hand side right?
dazzz wrote:I'm no expert but
klx_boy
Post by klx_boy »
Yeah battery is round the right way.
All ignition lights come on and stuff. Just really worried about these earths and if i connected the starter properly.
Its been a while since i took them off! Doh!
h180eeu
Post by h180eeu »
I may be completely wrong but isn't the point that you think is an earth the min power feed to the starter? Trying to remember to when i pulled mine apart
klx_boy
Post by klx_boy »
Exactly! Thats why i need a pic of a starter to see.
I think your right. Ive made a total balls of this lol
I have taken a pic of where i have it connected. I will upload it when i get in.
klx_boy
Post by klx_boy »
Heres two pics of the wiring. The thick black one at the top is the one im guessing is my starter feed? That was the one smoking/i thought was an earth.
The other one to the right and down was also loose but i do think think this is an earth?
alanmr2turbo
Post by alanmr2turbo »
yep thats the start feed
klx_boy
Post by klx_boy »
Yessss! the big one?..
Where on the starter does it attach?
When feeling it i can only find what feels like a spade connector terminal and thats the firewall side.
Thanks for all help! Its really really appreciated :D
alanmr2turbo
here we go big one goes here
klx_boy
Post by klx_boy »
Blinding! thanks very much :D
klx_boy
Post by klx_boy »
Sorry to be a pain once more haha
Went outside and seems that i have already connected the wrong wire to the starter..
Any idea where this one belongs? is this an earth?
alanmr2turbo
thats correct but you still need to connect the thick wire (that you have attached to the body work) to there as well as the one thats there already
klx_boy
Post by klx_boy »
Ahhh okay so that tab has two wires coming off it? The wire above goes towards the boot and joins in with a load of other wiring? Is that correct.
alanmr2turbo
yep, so just take off the nut and attached the thick wire to there as well :thumleft:
klx_boy
Post by klx_boy »
What a help! Thanks soo much! If your ever up Middlesbrough way i owe you a pint :D :thumleft:
Return to “Electrical”
