Just thought there's another quick test before taking the head off, but it's all really pointless as i don't think anything bar a stuck bucket is going to revive compression.
anyway.
take
#4 plug out and dribble a little oil down the plughole, repeat the compression test on that cylinder, if it shoots up momentarily to healthy it's a ring/HG issue, if it only goes up slightly or not at all then it's valve burnt/stuck open or holed piston.
That only delays the inevitable which is head off anyway.
Another test involves using a tool i made, not sure if you want to go to the trouble but i'll mention it anyway, i hollowed out an old spark plug, so it was just the threaded part and the
"nut", then welded a 6" tube onto that and then welded an air line fitting onto the end of the tube, so it was plug/tube/air fitting.
This allows you to screw it into the cylinder and carry out all sorts of magic tests by applying 50psi to the cylinder and watching/listening where it goes to.
With valves shut, you should only hear a very slight hiss as air blows by the rings, but with the oil cap off if you can hear a lot of air then it's a good indication of rings.
If you can hear air in the plenum then it's a burnt out/open inlet valve, if you hear it in the exhaust it's a burnt out/open exhaust valve.
if the coolant starts bubbling it's a HG breach between bore and waterway, it's a great diagnostic tool without taking anything apart and has saved me countless hours over the years.
Not sure if that is any help but there you go
