Camber bolts
leeclark2010
Camber bolts
Post by leeclark2010 »
Just after some info about what camber bolts people would advise for me. The car has Tein s line springs with standard dampers filled with millers heavy damper oil, standard arb's, all poly bushed. I can only use Toyota bolts which can either be .25, .50, or .75 I believe , the car is on the road 90% of the time and I've gotta say it's already as tail happy as I'd like in the wet, so do I buy 4 of each and book a track day or can you give me a few pointers people? Any avise appreciated but I fully understand that this is a personal thing, but I want to err towards understeer and my already tight budget is getting tighter!! Lol! :D
alanmr2turbo
Re: Camber bolts
Post by alanmr2turbo »
no you just buy 2 fronts and 2 rears then get it 4 wheel aligned
Ebay £22 a pair delivered as i just bought some for the front
Peter Gidden
Re: Camber bolts
Post by Peter Gidden »
Toyota "crash bolts" or camber bolts are about £5 each. Cheap, but on track can be knocked out of position as they rely on nothing but clamping pressure.
Eibach bolts, which have an eccentric cam, are about £25 per pair. More expensive, but will not go out of adjustment.
leeclark2010
Re: Camber bolts
Can't use the eibach, gotta be from mr t.....
leeclark2010
Re: Camber bolts
Had no idea they were so cheap either!
Peter Gidden
Re: Camber bolts
leeclark2010 wrote:Had no idea they were so cheap either!
I keep them in stock.
