A copy of this is on mr2.ie and mr2australia.com
Anybody in the group buy please read it carefully and give your answer on this forum.
I need to find out which revision MR2 everybody in the group buy has.
If you are not sure of the revision, the year of the car will do.
Please post your answer here.
I will make a list on the forum of all the customers and the revisions they have.
There is a overlap regarding revisions for 1993.
Revision 2 stopped around the month of September.
I'm afraid you will need to find out for yourself if you have a 1993 MR2 and are not sure which revision.
The car could have been modified by a previous owner, so don't assume just by something like the type of rear lights that are on the MR2.
For those who have bought a spare power steering rack for this project, you will need to know which revision it came from.
If you do not know then you will need to take measurements of the pinion.
Please send me a pm for more info.
If you do happen to get it wrong, then all is not lost.
It will mean that you will have to purchase new bearings which are different in size.
This means that if you change the bearings you could use a revision 2 in a revision 4, but it is more expense.
If I have not received an answer from any customer by the start of October then I will send them a pinion for revision 1
& 2, as I am sure most of us we would agree that we have waited long enough.
Thanks to the people who have replied to the email I sent a while back.
Can I ask all of you who are in the group buy to reply on this forum as to which pinion you require.
This is so there is no misunderstanding on both sides.
For revision 1 and 2
= 1989
- 1993
= pinion A.
For revision 3,4 and 5
= 1993
- 1999
= pinion B
Thank you.
