Cheers guys
I used 3mm led's for this conversion, as mentioned above
- nearly 200 of them
With standard led's, light bleeding isn't really a problem
- as it's focused light.
Wide angle bulbs would probably be a bit brighter, but you'd then have bleeding to contend with.
Basically, to do it, you need to remove the gauges and strip them down to just the clear polycarbonate screen.
Then, mark where all the dashes and numerals are, and glue led's in the correct locations.
Some of the numerals
- mainly the triple figures on the speedo
- have 5 leds to get the lighting correct, without
'hot spots'.
Also, I used resistors on every 3 bulbs, to avoid getting any
'cold spots'.
It's a very laborious job, and extremely fiddly, but the results are incredible.
As clear as speedhuts, but completely personal with respect that any light combination can be used
And cost about
£15
