Coilovers on Mk1s
Re: Coilovers on Mk1s
Are they cheaper for a MK2 then?
Retro_Boy_G wrote:Are they cheaper for a MK2 then?
The number of companies who do suspension for a Mk1a is dwindling to zero.
I don't think the Mk2 suspension kits are any cheaper than Mk1s at the moment.
Ahh cool.
I take it that it works out a lot cheaper doing this mod than spending
£749 on BC Racing ones?
Gad wrote:Someone remind me why I bought a bloody 1a again?
Seems to make sorting decent suspension an extra pain in the ar$e.![]()
If mk2 struts fit a mk1b then I can't see any reason why doing something like this wouldn't let you fit them to a mk1a:
http://www.imoc.co.uk/forums/viewtopic.php?t=157429
Retro_Boy_G wrote:Ahh cool.I take it that it works out a lot cheaper doing this mod than spending
There's more choice from the MK2 range of suspension products and probably more chance of finding something second hand.
New prices won't be much different though.
I was wondering why people would do this tbh, you can get BC Coilovers for a MK1 anyway, and I have a set of Ledas on mine.
I am almost certain if you asked Meister R they could come up with a set too
(I can ask them as I know the guy that makes them if anybody is really interested).
I guess if you've got a cheap second hand set of MK2 ones then it might be worth it if you're a bit handy.
But otherwise can't see why you would?
- Location: Castle Donington, home of fast cars and strange festivals...
kaiowas wrote:Gad wrote:Someone remind me why I bought a bloody 1a again?
Oh that's interesting, the last I'd heard I'd be looking at shifting over a whole 1b suspension set up.
elbon50 wrote:
Any chance of a cost price group buy Charged![]()
Not an option really unfortunately.
tonigmr2 wrote:I was wondering why people would do this tbh, you can get BC Coilovers for a MK1 anyway, and I have a set of Ledas on mine.![]()
I guess if you've got a cheap second hand set of MK2 ones then it might be worth it if you're a bit handy.![]()
I'm going to do it because I rate the quality of tein and kw to name two, above those of bc and d2, and i prefer the adjustability of coilovers.
I emailed LEDA for a suspension quote.
I sent:
Many thanks
Alex Paulukiewicz
the reply;-
Alex,
Leda can supply a set of two front coilover struts and two rear coilover dampers for the MR2 at
Currently supply of new shocks is approximately 8 to 12
weeks from order due to current volume of work.
Regards,
xxx xxxxxxxx
Ive been looking for a set, i really want them, but i haven't got that kind of cash to spend on them.
Id be interested T, If they need a car for measurements or anything also providing they are not miles away id be willing to help out!
Alex
charged wrote:Mine's probably screaming'stop raping me'
Yeah I must admit my Ledas were
£2K.
.double adjustables though.
I will ask Meister R.
BC Coilovers aren't half bad actually, have been pleasantly surprised on the racing roadster.
i know that XYZ and BC do MK1 coilovers.
i have been thinking about those a while back, but then decided to go the KYB+Eibach
(apex?) standard suspension route.
but if my standard suspension parts are rotten, then BC it is
stenky wrote:i know that XYZ and BC do MK1 coilovers.i have been thinking about those a while back, but then decided to go the KYB+Eibach
There are also other companies who do coilovers for the Mk1b
If you have a Mk1A just switch to Mk1B rear subframes and hubs, then you too can do this.
I've lashed out
£1300 on a set of KW version 2's that are only available for the Mk2, for my Mk1 project, and the Mk1 V8 has Mk2 Tein superstreets with EDFC, although to be fair i didn't swap the topmounts on those for Mk1.
The only pitfall using Mk2 stuff is wether or not you can swap the top mount easily, so far i haven't failed to do it, but i'm Paul Woods and i rock
<--- that's my new siggy.
Seriously though, just be sure before buying, some of the Mk2 damper tubes might be thicker diameter than Mk1 top mount bearings, so some machining might be needed, but every set i've adapted have worked.
I've lashed out
