[Mk2] [NA] rev3 na to tubby
shoky
Re: [Mk2] [NA] rev3 na to tubby
Post by shoky »
im gonna get the rear lights sorted and then check on that brake pedal light. As for the oil light As long as its not oil pressure light im not fused. cheers guys thumleft:
alanmr2turbo
Post by alanmr2turbo »
Shoky have you fitted the Turbo clocks or left the N/A ones in?
When i did my conversion i used the Tubby clocks and no lights came on.
Kinsy
Post by Kinsy »
The connector down near the sump is for the oil level sensor. If the turbo sump doesn't have anywhere for it to plug into, just bridge the contacts and use the old fashioned dipstick :)
shoky
Post by shoky »
ive still got my na clocks in but will need to swop over anytime soon as the speedo is not working due to the turbo box having a manual speedo cable, as for the oil level light thers no connector on the the turbo loom. anyone know which wire on the chasis side of the loom it is so i could sort that out. too be honest not too fuss'd about that the engine is boosting well im just loving it :D
goggins1234
Post by goggins1234 »
hi all im the process of swapping rev3 turbo 1996 into my uk n/a 1997 I changed the passenger loom and there's an extra plug but theres no socket for it in the kick panel. id really appreciate some help. sorry to post on here desperate for help
Peter Gidden
Post by Peter Gidden »
goggins1234 wrote:hi all im the process of swapping rev3 turbo 1996 into my uk n/a 1997 I changed the passenger loom and there's an extra plug but theres no socket for it in the kick panel. id really appreciate some help. sorry to post on here desperate for help
Told you the answer on your other thread. Easiest way out is put your original body loom back in.
I, and Paul Woods, NEVER change body loom!
rev3turbo
Post by rev3turbo »
should have just left the existing loom in, there was no need to replace it.
Peter Gidden
shoky wrote:ive still got my na clocks in but will need to swop over anytime soon as the speedo is not working due to the turbo box having a manual speedo cable, as for the oil level light thers no connector on the the turbo loom. anyone know which wire on the chasis side of the loom it is so i could sort that out. too be honest not too fuss'd about that the engine is boosting well im just loving it :D
1) Fit an electric speedo adaptor to gearbox.
2) Remove oil level bulb in dash.
Peter Gidden
Kinsy wrote:The connector down near the sump is for the oil level sensor. If the turbo sump doesn't have anywhere for it to plug into, just bridge the contacts and use the old fashioned dipstick :)
Bridging won't put the bulb out. The N/A sump contained a level sensor, not a switch.
Solution is to remove bulb from dash.
goggins1234
ok peter I can do that this morning shouldn't take long and thankyou for your help :-)
Peter Gidden
goggins1234 wrote:ok peter I can do that this morning shouldn't take long and thankyou for your help :-)
Get your body loom back in - and don't forget the earth ring behind the passenger seat. :thumleft:
goggins1234
ok going to do that know
