MartG wrote:BarronMR wrote:
Indeed lol, I was just trying to say that more piston area ie bigger calipers will *not* shorten your stopping distances, purely because you have more brake force. But a bias change will.
Not necessarily - in the standard setup the rears aren't providing as much braking as they could thanks to the bias valve. With ST165 front calipers and the bias valve gutted the bias is approximately the same as standard, but overall braking is improved whilst still having the safety of the fronts locking before the rears.
And don't forget that in most cases cars with upgraded brakes will usually also have more overall grip than standard as they'll probably be running bigger modern tyres with more grip than the OEM ones back in 1985 so are less likely to lockup with the higher braking forces IYSWIM
100% agree with that, it's also reinforced by real world experience which confirms exactly that.
