KarlBristol wrote:The drivers window control sections (for both windows and the window lock)- is this one single led or several??
Early revisions (revs 1 & 2 IIRC) had 3 LEDs.
Later revisions (rev3+ IIRC) had only 1 LED for the 'auto' switch.
JohnnyC wrote:KarlBristol wrote:The drivers window control sections (for both windows and the window lock)- is this one single led or several??
p5ycho wrote:MR2O12 wrote:
I then took 2 of the same bulbs and removed the blastic holder at the bottom, then took heater control apart and fit these inside, soldered the legs of the bulb directly to the heater circuit board, and also had to modify the light reflector to get the bulb to fit but you can see the light spread in the pic, I have no hot or dark spots and everything lights up nicely..
This looks nice and more straightforward from the led strips I was planning to give a go at. So you removed the 3 (or 4) bulb plastic holders on the heater board (that keep the original bulbs) and soldered these bulbs where the respctive holes are on the heater board? How did you modify the reflector?
hygt2 wrote:Quick question, if you change the cluster and heater control bulbs to LEDs, would the light dimmer still works to dim the interior or the LEDs are set only at its brightest setting?
Rob wrote:^ How come you have 2 Auto switches?
No SW20 came with passenger side Auto - have you retro-fitted it???
Vampire wrote:Psyco - fancy eraning yourself some money as im desperate to have an auto up/down for the passenger side! thanks
p5ycho wrote:MR2O12 wrote:I then took 2 of the same bulbs and removed the blastic holder at the bottom, then took heater control apart and fit these inside, soldered the legs of the bulb directly to the heater circuit board, and also had to modify the light reflector to get the bulb to fit but you can see the light spread in the pic, I have no hot or dark spots and everything lights up nicely..
You used resistors with these right?
biohazard wrote:p5ycho wrote:MR2O12 wrote:I then took 2 of the same bulbs and removed the blastic holder at the bottom, then took heater control apart and fit these inside, soldered the legs of the bulb directly to the heater circuit board, and also had to modify the light reflector to get the bulb to fit but you can see the light spread in the pic, I have no hot or dark spots and everything lights up nicely..
the led bulbs I used were 12v 501 type so no resisters needed..
p5ycho wrote:Vampire wrote:Psyco - fancy eraning yourself some money as im desperate to have an auto up/down for the passenger side! thanks
I would love to mate.. and i would be glad to help,.. only problem is one touch windows on passenger side aint an easy task.. unless you have a one touch window module..
switches is another game all together...
if you want the window module fitted I can indeed do it for you.. drop me a pm and we can sort out a price and place.. thanx
Rob wrote:p5ycho wrote:Vampire wrote:Psyco - fancy eraning yourself some money as im desperate to have an auto up/down for the passenger side! thanks
Is there any way you could do a write up? I too would love this feature......
