[Mk2] [NA] N/A Water Leak - Where do I get the gasket from?
Lincs-SW20
Post by Lincs-SW20 »
As always seems to be my luck, I've just fixed one leak, only to find another!
Please see the photo below, it's the gap between the small rigid coolant pipes and the side of the thermostat housing which is where the water is coming from.
Any advice on where to get the gasket from would be great!
Peter Gidden
Re: [Mk2] [NA] N/A Water Leak - Where do I get the gasket from?
Post by Peter Gidden »
If leaking from behind that flange, It'll be either an O ring, or a flange gasket. Replace both at same time. We keep both in stock.
Lincs-SW20
Right ok thanks.
Please can you give me some details of how to order?
Cheers.
Peter Gidden
You have PM.
