I think if it was that much of an
BTW Chris stickers Plz
charged wrote:Mine's probably screaming'stop raping me'
pk_090 wrote:There was no mention of carbon brakes apart from"carbon lorraine" who are a performance pad and disc manufacturer.
I dont know if you have read this thread, but during the hours i am not at work i make items in carbon, kevlar and fibreglass.
Nothing large scale, as it is done at weekends when no in work and using wages after everything else has been paid for which often leaves not alot.
The parts i make usually end up on either my cars, or friends cars, or as current my mousemat and coffee coaster at work.
Not just composite work i enjoy doing but i have done a full race prep from start to near finished at the moment
on my friends integra DC2, including a full strip, seam weld and weld in roll cage install, custom strengthening to the body above the roll cage to interior and exterior, full spray job with the roll cage and engine bay in Focus RS green, with the exterior and interior in Honda white.
Carbon paneling on the inside, along with carbon detail in the engine, and currently designing a proper working flatbottom and diffuser that actually works
(CFD and wind tunnel tested).
In terms of suspension, i have been looking at multiple avenues.First route is some BC coilovers and camber adjustable top mounts.
Expensive option, more track orientated than anything.
Second Shocks and springs.
Again a good cheaper option, that can yeild the same results in my opinion.
The both achieve lower ride height and stiffer suspension, at the expense of not being able to lower the ride height once the lowering springs have been selected.
Third, this may get slandered but an alternate spring.There are many differant suspension setups that work on differant cars.
For example astra front and nova rear springs, are a perfect fit on BMW E30's as lowering springs, there are more combos such as this.
Alex
pk_090 wrote:I draw security fencing.Its not the most glamorous things to design.
Ive been using resin infusion which as you say does not give as good quality as pre-preg parts but i dont have, nor have access to an autoclathe to cure the pre-preg carbon.![]()
Resin infusion isnt bad in terms of resin coverage, there is normally only waste where ive mixed too much resin than for what is needed as the excess just gets sucked back though the lines into the store.
How have you been curing your pre-preg?
Alex
AdamP wrote:pk_090 wrote:I draw security fencing.Its not the most glamorous things to design.
Alex
Autoclave.I haven't attempted it at home
(I admire those who do!) but I used to spend my summers working at an engineering
/ motorsport company that specialise in composites.
They made these:
http://www.motorsportads.com/assets/pro ... -73888.JPG
pk_090 wrote:That's quite a big word, i don't know the definition of Chris! I assume it means pain in the ar$e?Im definitely looking forward to the results though sounds like a good combo, but how much of a drop is it?
I think if it was that much of an"embuggerance" im sure i could have persuaded you to have kept them on my car.
BTW Chris stickers Plz![]()
pk_090 wrote:I hope its the kind of shooting that we wont see your face on bbc news tomorrow morning?
