suppose everything can wear out, particularly if it's not be maintained as it should be evryone whose owned it.
.oil etc.
.but man.
.if you've ever split one of these boxes and had a poke about.
.they're built like the vault door at Fort Knox.
.have you ever had the driveshafts replaced? is it the case that, earlier cars have one slightly shorter/longer drivers side shaft.
.I have a vague inkling in my head that I have recently read a thread with this in it, can't vouch for it's vallidity though.
I would be taking it for a second opinion matey, alternatively, you could pick up an lsd box for around the
£300 mark from an affiliate who has looked it over or has knowledge of the vehicle it came from.
.best way to buy if your not car part savvy.
Tip.
.if you do decide to split the box and have a poke around, read the guide and don't lose the grommet.
