I have just bough my first mk 2 but i have a problem with alarm.
The sellar advised that he disconnected the battery over the winter and when he put it back on his alarm kept going off and the car would not start.
He has pulled the fuse which means that not only the alarm wont go but the stereo, interior light and clock are also out as on the same fuse.
His garage say that it need to be put on the machine at toyota and they will sort it out.
I just though that i would ask some advise on here to see if anyone has had a similar situaton and if they can give me any ideas on the problem and if i can sort out myself.
Can i just disconnect the alarm at present so i can get the fuse back in and the rest of the bits working.
Apart from this the car is swell.
