Also anyone have any views on removing TVIS while its in bits? Will this loose me torque low down? The car is running about 280bhp at 1.1/1.2 bar boost.
Thanks in advance.
craig_mr2_mk1 wrote:Yea he is replacing the it with a Revision 3 MLS Gasket.As for plugs mate, I'd use Grade 7's.
Off the top of my head BKR7E's is what I used when I had bolt on mods the same as you.
The not special plugs not Iridium, they should cost you no more than
£2 each, Just change them every 3k
- 4k.
Craig.
.the only thing I can promise for sure is slow progress.
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.![]()
Thanks in advance..
Shmed wrote:
Not got real life experience of the differences of removing TVIS, but at least make sure it's actually working.If the actuator is gone, you'll lose a lot of flow.
Shmed wrote:craig_mr2_mk1 wrote:Yea he is replacing the it with a Revision 3 MLS Gasket.As for plugs mate, I'd use Grade 7's.
- 4k.
Craig.
Is that the same part you'd use for a 400bhp(not confirmed) rev2/3
(rev2 block rev3 head)?
Century Motorsport wrote:BKR7EIX
sjm1984 wrote:christ, i'm running NKG BKR9EIX(STOCK CODE: 2669)
Harold wrote:sjm1984 wrote:christ, i'm running NKG BKR9EIX(STOCK CODE: 2669)
Are you running some kind of crazy bhp?
sjm1984 wrote:Harold wrote:sjm1984 wrote:christ, i'm running NKG BKR9EIX(STOCK CODE: 2669)
close to 2 bar on a gt3076
What my builder recommended
