Also 6 speed? Let me get my head round this, you gutted a factory 5sp mk1 box,& dropped in a celica's 6sp internals?
& it fits without modification? Theres space for the 6sp cog? what about the ratios compared to the mr2s factory? Then dropped in a mk3 mr2 lsd, again without mods? What about gear linkages/gates?
Basically the Celica 6 speed and the Mk1 box are both C series transmissions, so i just used the Mk1 bellhousing section, gutted all of the Mk1 internals, put the Celica bearing races from the Celica bellhousing into the Mk1 bellhousing
The centre case is Celica, as is the end casing where 5th and 6th live.
The Mk3 Mr2 gearbox is also a C series
What you should end up with is Mk1 gearbox utopia, all of the best bits from every C series transmission all in one unit.
The only thing that needs modifying will be the gear cable bracket, i will need to make one of those up in situ when the box gets fitted, but my original Mk1 cables will work on the 6 speed and using the Celica box means the linkages are on the correct side.
Driveshafts can either be Mk2 NA shafts
I will be making jigs for both the axle bracket and gear cable bracket should anyone wish to copy it.
