Ok last Sept I bought an Exedy clutch for my 1996 MR2 GTS only just got round to fitting it and its too small, can someone please tell me when the clutch size changed?
a 3sgte clutch is the same for all revisions, a rev5 turbo clutch will fit a rev1 and vice versa, they're the same fitment
I suspect the clutch you have been supplied is for a 3SGE engine
Ok thanks guys
21 splines on the turbo clutch and 270mm PCD on the bolt holes
and
20 splines 265mm PCD on the clutch I was provided
does this sound like an NA clutch?
They don't last long in road applications either as they wear out fast when you slip them.
I had a three puck paddle on my charade turbo, lasted me 5000 miles of daily driving. 5000 hateful, horrible miles of juddering nastiness.
Freebird wrote:Sorted, I have now got a ACT Xtreme 6 puck sprung centre with a Heavy Duty Pressure Plate, just hope its not too harsh.
Cheers guys
Sounds like the same one as i have, meant to hold silly levels of torque. However it's an absloute monster to operate. Also chatters quite viciously when setting off at revs below 2000 rpm
If it was my daily driver in England I'd either have legs like popeye or i would have changed it a long time ago.
