As its a straight run and therefore completely in tension and compression
Aluminium is not a material to make strut braces out of! Constant change between compression and tension leads to short fatigue life.
aw11rally wrote:I've got them now.
Here is a pic, very simple and very functional.I like them but they need to lose weight before they go on the rally car.
The bar will be replaced with tube or box section alloy or stainless.We might even get the plates CNC cut from 5mm alloy if we can get it done on the cheap I.e.
Free.
aw11rally wrote:I'm sure rose joints will be involved.25mm tube would be more than man enough for the job.
We'll see what we can find.
Carbon would be nice, none has found it's way onto the car yet, it would be ideal, very strong in tension and compression.
Aluminium is not a material to make strut braces out of! Constant change between compression and tension leads to short fatigue life.![]()
PW@Woodsport wrote:Aluminium is not a material to make strut braces out of! Constant change between compression and tension leads to short fatigue life.![]()
Not sure i agree there, these have lasted ten years or so and many strut braces i have seen are made from aluminium.
PW@Woodsport wrote:All of this over a brace i was making 10 years ago![]()
It was my first attempt when there was pretty much nothing already on the market at all for the Mk1, i didn't have half of the access to tools and equipment that we do these days and i only thought about over engineering the job rather than making something weak..
mission accomplished.
If i were to make one these days it would be much lighter, but i think i'd still use a solid alloy round bar with machined ends to take adjustable rose joints and laser cut flanges for the strut tops.
In my opinion a lot of the hollow tube braces i have seen for sale are doing absolutely nothing in terms of bracing the strut towers and are only sold for show ponies.
AdamP wrote:PW@Woodsport wrote:All of this over a brace i was making 10 years ago![]()
I apologise, I didn't mean to place doubt on the quality of your work, i'm merely coming at it from an engineers point of view.
Any strut brace with a bend in it is going to be doing very little in the way of stiffening things up, whether it's solid or tubular, so you can discount those immediately, but I think you'll find that the vast majority of spaceframes(which a strut brace makes up part of) are made from tubular steel because its properties make it ideal for the application.
I don't really see why you'd want to use solid ali bar though, when CDS is much lighter, much stiffer(less likely to bend under compression), just as strong and much more resilient to fatigue.
I know it can look nice all polished up but there is just no engineering reason to use it.
For the same reason that you won't find any ali spaceframes, it just doesn't lend itself to use in that application.
scomr2 wrote:You can actually find quite a few aluminium spaceframes- Audi A8, Ford GT40, Lotus Elise.
scomr2 wrote:AdamP wrote:PW@Woodsport wrote:All of this over a brace i was making 10 years ago![]()
It's very easy to blame fatigue failure on the wrong material but far more often it's poor detail design.![]()
The stiffness of most strut braces will be dominated by the design of the interface between the tube and the strut tower mounting plate- most look pretty horrible.
Ideally the brace tube should be straight and in the same plane as the mounting plate to minimise any bending.
None of those are spaceframes..
scomr2 wrote:
Perhaps not by your definition but others seem to disagree;
Scroll down to audi asf: http://www.autozine.org/technical_schoo ... assis2.htm
Another one: http://www.autoblog.com/2010/03/01/fisk ... -revealed/
Ford GT40: www.aec.org/assets/pdfs/ShwcsFrdGTfinal.pdf
A space frame is a geodesic structure that carries suspension loads with the body panels essentially unstressed- completely different from a monocoque.
Accepted the elise is not a good example- the others are.
Interesting! The definition of a spaceframe I have infront of me is a'Three-dimensional truss composed of linear elements subject to only tension or compression', which makes referring to any of those three as a space frame dubious, but thats another discussion.
They are certainly closer to it than I had realised.
The point is that aluminium WILL fatigue under those conditions, especially at the stress concentrations(in this case the joints).
Audi spent many millions of pounds developing the correct alloy and bonding methods to reduce this to an acceptable level while maintaining the weight they were looking for.
Woodsport brought it to an acceptable level by increase the tensile strength.
It still doesn't make it an ideal material.
scomr2 wrote:
Aluminium is only different from Steel in that it doesn't have a well defined endurance limit.
