It's worth taking the hoses off and inspecting them.
.some of mine were splitting and de-laminating, but you couldn't see that untill you had them in your hands and squished them up a bit.
.particularly the hard to get to one at the back of the IC as it's right over the downpipe.
.after replacing all the hoses and clips
(stainless jubes are about
£1.50 each and
£8 for 250mm of silicone hose).
.I sealed all the joints with a smear of high temp silicone.
.made a big difference on and off boost, bov is more active and responsive.
.all in for
£20.
As yours is rev2, I would also remove and inspect the AFM, which also gives you the opportunity to check the turbo and have a sketch around that part of the engine.
