Brian at T.F.S very kndly compression tested my rev2 last week.
.more or less 195.
.200's across the board.
This was done on a warm engine with throttle held open, efi fuse disabled and 5 cranks.
.I thought I might be getting excessive oil blowing out of the crankcase breather, so I hooked up a catch can for the journey and went for a comp test.
.no oil whatsoever in the catch can but the turbo IS blowing fresh oil even though the shaft doesn't have any in/out play in it at all.
.enough to leak out of the throttle body assembly and slightly pool on the rockerbox support bracket.
.with a thin 5-30 oil in it.
.the bov would blow oil vapour out and coat the engine bay.
.well that bit of it.
