understeer
understeer
i'm having probs with understeer in the fast long bends is there a solution or a driving technique to help.
Re: understeer
you could try getting a stiffer rear sway bar, that usually helps understeer...
are you running same size tires on all 4 fours? thats important too
Re: understeer
Do you have a rear strut brace?
Moved as much weight forward as possible?
Re: understeer
no arb front or back
Re: understeer
Try fitting ARBs and go for a stiffer setup at the back, softer at the front may help front end grip and weight transfer.
What kind of geometry are you running. Too much front negative camber has given us understeer in the past, also try the fronts parallel and maybe less rear toe in.
Re: understeer
What is the setup on the car for a start? Its obviously nowhere near standard, so its going to be extremely hard to diagnose a handling issue based on no information. Last I heard (when I was looking at buying it lol) the car in your picture was running Leda coilovers and weighed next to nothing, so its far from a standard AW11.
What springs rates is it running, geometry setup, tyres, etc? Is it understeering on the road or are you talking about track use?
Re: understeer
It really depends on where your understeer is occurring and what is causing it. The easy way is stiffen rear springs but that could be sacrificing rear end grip when the actual problem is damping, tyres or geometry.
Presuming those three are all in check, my suggestion would be to add adjustable anti-roll bars. It gives you an easily quantifiable way of adjusting wheel frequencies without affecting static geometry, so you should be able to dial out understeer quite easily.
However if you could post some details of your setup it would be a bit easier to suggest where it could be compromised.
Re: understeer
Leda coilovers springs rates not known but hard all around. r888 205/50/15 tyres. geometry front -camber is -0.9 rear is -1.5 front towin is 1mm rear is 4mm.
battery is in the front but its just a red top 30
Re: understeer
First step then is to have the spring rates measured
Re: understeer
yes will do was going to send them for a refurb but get no reply from leda.
Re: understeer
Gaz can service them as well. if you want the spring rates checking then let me know, weve got a damper dyno with spring testing facilities.
Re: understeer
Jim-SR wrote:Gaz can service them as well. if you want the spring rates checking then let me know, weve got a damper dyno with spring testing facilities.
If Gaz can service them then i would talk to them. They have been extremely helpful with the coilovers for my hillclimb car.
Re: understeer
the car has gone for mapping then racing in tss this weekend i will have them off after.
Re: understeer
rikster wrote:i'm having probs with understeer in the fast long bends is there a solution or a driving technique to help.
Driving technique would be:
If you are cornering under power = more understeer
ease off power (and there is more weight at the front) = less oversteer
You can then tinker with toe in/out and camber
- Lauren
- IMOC Committee
Re: understeer
Lifting off to get oversteer is acceptable.
Then you just got to hold it.
2020 GR Yaris - Circuit Pack
Re: understeer
aw11rally wrote:Lift off? Never!
In my other halfs old Mk1 you could lift off mid corner get the ar$e end out then either plant it and get it back or stay off the gas and it'd come back to you. Never driven a Mk1 like it. I've no idea what the alignment was like but as far as suspension it was on stock springs all round and tired old stock rear suspension with KYBs at the front.
Re: understeer
Ok ok, lift off or clutch kick. But we're trying to get rid of understeer arn't we? Not induce oversteer!
Re: understeer
rikster wrote:no arb front or back
A pair of Whiteline adjustable ARBs, then play with their stiffness to achieve the desired effect
Re: understeer
What do you mean by a fast long bend? eg quantify speed and bend?
One of the most thrilling aspects of my mk1 is nailing it at silly speeds in 4th gear. I always thought it was brilliant at this even though it was very twitchy. Lifting off would be unthinkable here
Understeer is more of a problem on hard cornering at low to medium speeds. At high speeds I always found the car to be quite well balanced on fast sweepers and keeping the throttle nailed is extremely addictive:)
If the car is understeering at very high speed I'd be wondering more about the suspension keeping the tyres on the road? Does the ARB do much at high speed? I'm afraid I know very little about car suspension
