[Mk2] [Turbo] Power Steering not working
esty112
Post by esty112 »
Hiya,
Just got in my car today and the power steering did not work.
Have a 93 turbo, had it for over a year with no PS proplems.
I know that it is connected to my anti-theft system, so not sure if it is the PS or the security.
When it normally works, you can hear the PS motor as soon as you turn the iginition on BEFORE starting the car.
But now, when I put the ignition on there is no sound and when I do start the engine the P/S light comes on.
Is there a fuse in the fuse box to check (if so where)?
I'll need to take a proper look this weekend, hope its just a fuse :-(
mark2
power steering fault
Post by mark2 »
I had a similiar problem last year and it turned out to be a solonoid with dirty contacts, it was recommended that i turn the ignition off and on about 30 times.....I didn't believe it would work :-k but hey presto it did \:D/ \:D/ as it cleans the contacts, so try that first and see if it works for you it's a hell of a lot cheaper :thumleft:
esty112
Re: power steering fault
Post by esty112 »
mark2 wrote:I had a similiar problem last year and it turned out to be a solonoid with dirty contacts, it was recommended that i turn the ignition off and on about 30 times.....I didn't believe it would work :-k but hey presto it did \:D/ \:D/ as it cleans the contacts, so try that first and see if it works for you it's a hell of a lot cheaper :thumleft:
Hi MArk2,
Well what do you know it worked!
But how does turning the ignition on clean the contacts????
and to think the garage recommend i see a electronics specialist!
Love this forum, every knows every thing about MR2's here :D :-k
mark2
power steering
Post by mark2 »
Well the way I understand it is ...
when the power steering fails due to this problem it's because the contacts within the solonoid/relay are dirty and not making contact properly.
When you turn on the ignition it activates the neccassary relays and creates a small spark within the contacts of the solonoid/relay and if you repeat the action in quick succession it removes the dirt and self cleans the contacts.
And hey presto you have your power steerings back :thumleft:
I hope this explains things and helps :)
mark2
esty112
Re: power steering
Post by esty112 »
All I can say it that this forum has just saved me well over £100 from taking this to a garage and my hours having to wait to get it repaired.
Totally love my MR2, it 17 years old and better than half the Euro car out today!
Thanks you guys :clap:
Moo
Re: [Mk2] [Turbo] Power Steering not working
Post by Moo »
Yup, this forum is great. The wealth of information on here has saved me a few quid over the years :thumleft:
