What's the best way to do this to ensure all the 5.1 is removed?
jasongtr wrote:does that still need the pedal pumping, id rather not risk damaging the seals
Harold wrote:Buy a Gunson eezibleed, it turns a brake fluid change into a very simple and quick one man job.
Bleed it[Smile]
RST wrote:Bleed it[Smile]
.drain it I would have thought.
Bleeding will just get rid of air.
When I change fluid I use a small tube with a one way valve in it.
I got mine from Halfrads for a fiver.
.the only thing I can promise for sure is slow progress.
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.![]()
Correct, bleed more from the calipers that are furthest away.Shmed wrote:How much fluid is there in the system? I seem to remember someone saying a litre is plenty to flush the whole system.The sequence is determined by distance from the master cylinder.
Do the furthest away first, n/s rear, then o/s rear, the n/s front then o/s front.
If replacing fluid, it makes sense that you should take longer doing the first one and progressively less for the others.
