Weight loss Tip of the Day for SW20 Turbo
Posts about trackdays and motorsport.
darcy
Post by darcy »
Not sure if this has been pointed out before, but I have just weighed a Rev 1 NA starter motor from a 3SGE- it is 0.9Kg lighter than its Tubby counterpart. Direct replacement wrt bolts and terminals, and should work OK.
Paul.
starkie13
Re: Weight loss Tip of the Day for SW20 Turbo
Post by starkie13 »
do u not think there's a reason for it being a lot more substantial on the turbo model... i.e a lot more compression...
jem
Post by jem »
starkie13 wrote:do u not think there's a reason for it being a lot more substantial on the turbo model... i.e a lot more compression...
The compression on the turbo is lower than the NA.
Return to “Motorsport and Trackdays”
