paint, thinners, and primer works out quite expensive as i found out, i got fed up as only thing i cant do is spray cars and decided to have a go myself starting off with a border bonnet i made, i can see why it costs so much by the time you buy the primer, the basecoat, activator, thinners, strainers, panel wipe, gun cleaner it costs a packet, and if your starting from scratch ie a compressor, spray gun, water seperator, preasure valve, spray gun hose
its even worse, im getting better all the time with my spraying and have just bought a devilbiss gun with a 1.3 setup which is suppose to be good for a home sprayer and gun works on a low preasure compressor.
you would need 2 of these if doing door shuts and doors and under bonnet and engine
cover with some spare to touch up with, just to give you an idea thats without primer and laquer, high build primer and laquer is not cheap aswell and activator and thinners, might be better off painter supplying the stuff to be honest also may use a supplier he likes some painters are a bit funny on who thay use painters preference, heres some rough guides for you cellulose only needs thinners added where as 2 pack needs thinners and activator to go off
http://cgi.ebay.co.uk/2-5LT-CELLULOSE-G ... 2a04e5b383
http://cgi.ebay.co.uk/2K-ACRYLIC-CAR-PA ... 3ef40c9868
http://cgi.ebay.co.uk/2K-PRIMER-CAR-PAI ... 5640bf25a5
http://cgi.ebay.co.uk/2K-Scratch-Resist ... 3cad9b00ed
heres my bonnet i painted myself and some dash plastics.
oh and my new gun i cant wait to use.
hope this might give you an idea need to know if using 2 pack or cellulose really to give you a better idea also a few painters on here will be able to help you better gave me a lot of good advice.
